0 Members and 1 Guest are viewing this topic. Read 1874 times.
What is each transformer being used for? In my opinion if you could separate each channel of Left and Right (what is the third?) especially with grounding, GO FOR IT.
I think these questions are better for someone else.
It's not entirely clear to me what the question is - you are building a preamp from scratch? I personally would try and go for a design that allowed for a single off-the-shelf transformer for ease of building and chassis work.
It depends more on the quality of the transformers. If a single transformer is of better quality than even two or three separate transformers, that would be the best route. Many companies have unique transformers designed for them for each application. We use a separate transformer for the B+ voltage and filament supply in many of our products where some of our other designs use a single custom designed transformers with high quality electrostatic shielding.If using a single transformer, having one with electrostatic shielding would provide the best results. A lesser cost version would use split bobbin nonconcentric winding. These are your usual off the shelf pieces. Separate transformers would be best in my opinion if lesser quality pieces are being used. Less noise. Just my two cents.
