0 Members and 1 Guest are viewing this topic. Read 13700 times.
I use one. It adds a sense of vividness to the music, while adding smoothness. It makes my system sound a bit more like music. It doesn't appear to have a downside when used correctly.The effect can be too strong if used improperly. It can be overkill if you plug it directly into your power conditioner, or power strip. To find the sweet spot of the effect try it a few outlets away from your sytem connections. Mine sounds best on an outlet next to but outside of my dedicated circuit.
That's just too wierd for me I can't say I have fiddled with placement. So, closer to a component does what?
The electroclears add a liquidity to the sound and add richness to the midrange. It's a good way to combat glare in the upper midrange.Used too closely to the audio system it sounds too ripe and rolls off the highs.
