using the Balanced version with an adapter
0 Members and 1 Guest are viewing this topic. Read 1457 times.
sdipiet
« on: 9 Jan 2009, 11:25 pm »
Does anyone know if you would lose a lot sonically if I had a 8.02 b with a cardas XLR/rca adapter? I was thinking about getting a used 8.02B but I'd have to use the adapter since I run single ended. Also, is the 8.02 the same thing as the 8 V2? I've never seen it called an 8.02 except in the ad for the one i'm looking at.
thx for any info.
samuel
rustydoglim
    • www.nuprimeaudio.com
Re: using the Balanced version with an adapter
« Reply #1 on: 17 Jan 2009, 09:58 am »
Ref 8.02 is not the same as Ref 8V2.  Ref 8.02 is our first 100W mono amp in 2005 and has been discontinued. But we can upgrade Ref 8.02 to Ref 8V2 (200W, V2 board)
