ACI Orion Loudspeakers ($425.00 OBO) - Phoenix, AZ
0 Members and 1 Guest are viewing this topic. Read 2750 times.
silvente
These custom/owner built speakers are made of Medium Density Fiberboard (MDF) for resonant free performance and are wrapped in red oak veneer.  Each cabinet is a separate subwoofer with floor pointed driver.  Cabinets house high quality Audio Concepts drivers and crossovers.  You simply must hear the sound quality of these speakers.
Asking: $425.00 (Located in Phoenix, AZ, 85050).  The drivers and components were $800 + when purchased new.  I'm selling the speakers to move into a smaller package.
Imaging, dynamics, frequency response and musicality are absolutely first rate.  The boxes are fully sealed with AC Foam throughout, ACstuff (TM) Stuffing in the subwoofer cabinets, and ACdacron (TM) Stuffing in the upper cabinets.
Here are the key features of the Orion's from Audio Concepts Inc:
Dimensions: 56x13-1/2x13 (2.5 cu-ft)
Range: 35 -20kHz (+/- 3dB)
F10: 23 Hz
Sensitivity: 90 dB (four Ohms)
Woofer: AC Inc., JC12 Dual Voice Coil
MidRange: Focal 5K013L
Tweeter: Focal T120K **
Power: 200 RMS
Bass Loading: Slot-load Aperiodic
Crossover*: All Polypropylene and Audio Grade Components 200Hz, and 4.5kHz
* All crossovers are hard-wired (not circuit boards!), for lowest resistance.  Wonder Solder (TM) used on all connections.  Gold five-way binding posts are installed which allow you to use: spade lugs, banana plugs, bare wire, or pin connections to your receiver or amplifier.
** One tweeter went out years ago and I replaced it with an equivalent in all specs from Focal.
The oak veneer is not discolored.  The garage door was open with glare coming off the car windshield
Here's a shot inside where they are set up for a local buyer to hear.
« Last Edit: 10 Jan 2009, 04:11 pm by silvente »
Cacophonix
Re: Orion Audio Concept Loudspeakers ($425.00 OBO)
« Reply #1 on: 9 Jan 2009, 02:39 am »
Post explaining how to post pictures.
http://www.audiocircle.com/index.php?topic=40968.0
