0 Members and 1 Guest are viewing this topic. Read 9496 times.
Don,ACI makes some very musical, sealed subs. I would put them on my short list. They also have a circle on this site.http://www.audioc.com/speakers1/speakers.htm#subwoofershttp://www.audiocircle.com/index.php?board=76.0Joe
This may be a little off-topic, but I've been unsure about whether the WLM Diva Monitor will go low enough for me or whether I'll need a sub as well. The Diva Monitor with the Control unit is said to go down to 32 Hz, which I'm not sure will give me enough bass. I also listen to a lot of latin, soul and reggae, so good bass is a necessity.Looking at some of the suggestions made in this thread, it looks like some of these subs go below 20Hz. How low do you need to go to get good (but not overwhelming and unnecessary) bass? Is there a big difference between 30Hz and 20Hz? Thanks.
Quote from: kingpin on 8 Jan 2009, 06:26 pmThis may be a little off-topic, but I've been unsure about whether the WLM Diva Monitor will go low enough for me or whether I'll need a sub as well. The Diva Monitor with the Control unit is said to go down to 32 Hz, which I'm not sure will give me enough bass. I also listen to a lot of latin, soul and reggae, so good bass is a necessity.Looking at some of the suggestions made in this thread, it looks like some of these subs go below 20Hz. How low do you need to go to get good (but not overwhelming and unnecessary) bass? Is there a big difference between 30Hz and 20Hz? Thanks.A big factor I think will be the size of the room you plan to listen in. If your room is small, I think the Diva with the Control going down to 32hz should be plenty. Keep in mind I think those measurements are probably taken in an anechoic chamber, so in-room response is probably better than you think. Myself, I have a pair of TP Minis which go down to 40hz or probably lower but in any case, in my small (12 x 15) room they produce a bit of low bass, but their mid and especially upper bass is quite taught and pressurizes the room nicely. I have a Zu Mini Method which runs to 20hz supposedly but I haven't felt the desire to set it up with my SP Techs in my room yet, though that is in part because I just got a new amp. I listen to some bass heavy music and definitely need it to be present as well.
What is a balanced amp? (I doubt if Don is running the optional PA adapter.) As far as I know ACI subs can take speaker outs from your amp to their input. An adapter is included with them for this.
A very interesting thread and the feedback has been tremendous. The sealed Omega and ACI subs are interesting, although I’m wondering whether the 8 inch woofer in the Omega can really serve the purpose of filling in the bottom end of the La Scalas (remember I’m a subwoofer newbie). I’d assume that you’d look for a woofer larger than the ones in the speakers you’re wanting to supplement if you’re hoping to dig deeper in the bass. On the other hand, Omega speakers appear to have a loyal and enthusiastic following.I noticed that certain sub models are recommended for small, medium, or large rooms without defining what these sizes represent. My listening room is 14w x 16l x 10h. I’d guess this is a “medium” room, right? Does this suggest a generally appropriate size of subwoofer given the particular speakers I have or is it more complicated than that? My assumption is that a medium sized room probably can accommodate a 10 or 12 inch subwoofer for purposes of supplementing (not replacing) the La Scala mid/woofers. An 8 incher might not move enough additional air to be worthwhile and a 15 incher would be overkill. I’m parading my ignorance here so I’ll contact some of the companies suggested and learn more.Thanks for all the help.Don
