0 Members and 1 Guest are viewing this topic. Read 7130 times.
Got any friends who want to have a mock wedding?
Dang, this sounds like more and more of a nightmare, as if I didn't know it would be one, already.Ok - flash or no flash for the candids, assuming I can get away with no flash during the day time? I don't know if I'm going to know anything about the room where the bride will get dressed, since it's not at church (big blessing, actually, the church is very unphotogenic.) I guess I'll just have to try both.As for the camera, if I am shooting with remote flash, I will be shooting full manual, so I don't know how many extra features I will need to mind on the camera. I'll probably also shoot RAW for insurance's sake, so that should be an extra measure of safety. If the D90 is anything like the D40, and I'm pretty sure it is, then I should be safe using TTL with on camera flash, as well. I'm not 100% with it, yet. The office Christmas party I shot with the SB-600 flash was hit and miss, although most shots were lost because of the flash lagging on recharge after a few hundred shots. I was using lithiums then, I'll probably be using rechargeables for the wedding. Seminarian, my favorite shots at the Christmas party were of child or mother and child, and I knew they would be crowd pleasers. However, I'm not sure about how many kids will be at this wedding. I don't think the bride and groom have much close family in the country.You know, I have an idea about trying out the group shot - thanks for hounding on it, guys. Between the second photog and the bride/wedding coordinator, I believe I have at least 2 shot lists, so that base is covered.Holy crap guys, I was scared before, but I'm getting more and more scared by the moment. Here's to hoping that my "shoot and judge the manual exposure" technique will be fast and on target on that day.
Ok, here we go again. I need to know how big the wedding party is, the size of the facility (depth of the sanctuary) and approximate light levels anticipated during the ceremony (just go in when it is empty and take some meter readings at ISO 400).
Your 18-50mm lens covers what is referred to as a film equivalent of 28-80mm, a range of moderate wide angle to slight telephoto.On your camera "normal" (the old 50mm) is about 30-32mm. Anything shorter than that is wide angle, anything longer is telephoto.
In the "formal" shots, if your wedding party is big do NOT zoom out to get the group in. It will make the people in the middle look larger than those on the ends. If possible, move the people on the outside slightly closer to the camera to compensate for the them being farther from the camera. If your light is high on a stand you have the flexibility to move YOU farther or closer to the group while the light remains at the same distance, thus keeping the same exposure. Try not to zoom if you can because the inconsistencies of perspective will be noticeable to the trained eye.If you shoot in the 35-50mm range it will also tend to make the background a little less sharp, and that is a good thing, because you don't want the eye to be looking at what is in the rear of the sanctuary; it is the people that you want to be sharp.
I'd also suggest that you but the light about 3-5 feet OFF of center. I put my light stand inside the pews so that the light is slightly angled and more flattering. And nobody will trip over it.Even better, divide the bridesmaids and out them on BOTH sides of the bride and groom, and space them about a foot or so apart. THEN put the groomsmen close behind the girls in the spaces you have created. This does several things. First it makes the wedding party less wide and strung out. That allows you to move closer to the group and makes their faces bigger, which is, after all the point. Second, it puts the (hopefully) more attractive members of the group. Lastly, no one gives a crap what the men are wearing so it is fine to hide those light-absorbing tuxes behind colorful dresses.When I shoot the formals with my studio strobe and a big umbrella or softbox I set the camera at ISO 400, 1/30th second (sometimes 1/15th if it is dark enough) and 5.6 and leave it there. When the bridal party is only two people deep that is more than enough depth of field for the people, and the slow shutter speed helps to capture enough ambient light in the background to make it seem evenly lit.
Get a small Rubbermaid plastic stool at Kmart. It'll easily support me, and is great for getting a little more height so your close-up shots aren't taken from a lower angle. For candids, get a SC-17 or newer flash cord and learn to shoot with the flash off the camera, or get one of those swivel brackets that hold the flash above the lens regardless of whether the shot is vertical or horizontal. Both of those options provide a much more flattering light.
Try to get to know the wedding party beforehand. If you are comfortable with them (and they with you), it will go more smoothly.
There is nothing wrong with the D40. Borrow another one if you can so that you don't have to think about changes when you put one down and grab the other.I have a D200 and D300 and it drives me nuts to remember the differences.Don't use ISO higher than 400 if you can avoid it.
Lastly, take comfort in this. Thanks to Walmart, digital cameras, and the general rush of modern life, I think a lot of people have lowered their expectations of what makes great or even good photography. I rarely see the interest in huge wedding albums that grace the coffee table, or huge stately wall portraits that last for generations. If you try to emulate the magnificent work you see in magazines it will just shake your confidence. Smile, don't let 'em see you sweat, and always be pleasant and efficient. If you get the groups done fairly quickly and keep people smiling, they will remember you doing a great job.If you want more info PM me and maybe we can talk. Keep in mind that I shoot digital much the same way as I do film, so these are methods that have worked great for me for a long time.
....The office Christmas party I shot with the SB-600 flash was hit and miss, although most shots were lost because of the flash lagging on recharge after a few hundred shots. I was using lithiums then, I'll probably be using rechargeables for the wedding. ....
...maybe you should bail out and live for another day. .
