Jolida Tube MonoBlocks and Matching Preamp
0 Members and 1 Guest are viewing this topic. Read 2541 times.
alfaromeo164
« on: 5 Jan 2009, 08:53 pm »
Technical Specifications:
3000A 200 Watt Vacuum Tube monoblock Power Amplifier
Rated Output Power: 200 W per channel at 8 ohms, 25Hz to 40KHz
Frequency Response: (at 1 watt into 8 ohms) 14Hz to 50KHz + 1dB
Distortion THD: Less than 1% at 150 W output, 21Hz to 28KHz
Circuit Type:  Ultra Linear, Class AB
Input Impedance: 100Kohms
Input Sensitivity: 2.35mV at 1KHz and 8 ohms for 200 watt output
Output Impedance: 4 and 8 ohms
Tube Complement: 2 pcs. 211 power output; 2 pcs. El34 power drivers, 2 pcs. 12AT7 power drivers
Dimensions: 11 in. W X 19 in. D X 9 3/4 in. H
Power Requirements: 110V-120 VAC 60Hz 180 watts-standby, 850 watts maximum (220 VAC 50Hz option)
Weight:  50 pounds (23 Kg) net, approximately 55 pounds (25 Kg) packaged
3000B Vacuum Tube Preamplifier
Max Output Voltage:  20 V
Voltage Gain:  20 dB
Frequency Response:  5Hz to 110KHz, 10 V
Distortion THD:  Less than 1%; 1 KHz, 10 V
Output Impedance: 600 ohms
Tube Complement: 2 pcs. 12AX7; 2 pcs. 12AT7
Dimensions: 17 1/2 in. W X 12 in. D X 4 1/4 in. H
Best Offer Over $3,000 for Both
Original Price New was $7,000 For Both
Condition 9 out of 10
Will Pay For Shipping :D
« Last Edit: 8 Jan 2009, 11:04 pm by alfaromeo164 »
alfaromeo164
Re: Jolida Tube MonoBlocks and Matching Preamp
« Reply #1 on: 12 Jan 2009, 07:15 pm »
Bump  :D Excellent Condition Great Power and Great Bass!
doug s.
  • makin' music
« Reply #2 on: 13 Jan 2009, 03:39 am »
if your taste in stereo is anything like your taste in cars, then that jolida gear has to be excellent!   :thumb:
doug s.,
w/tweaked gtv6 3.0 as present daily driver; past rides included 3.0 gtv6, two milano werde's, one milano silver and a 164L...   8)
alfaromeo164
« Reply #3 on: 13 Jan 2009, 04:06 pm »
Thank You Very Much For The Reply Doug S I Was Fortunate Enough To Have Owned Two Exceptional Sources Of Enjoyment However I Am No Longer Able To Afford Either That Is The Only Reason Why I Am Selling The Jolida Tube Amp And Pre-amp :bawl: I Owned A 164S Wish I Had A Chance To Drive A 164 24v
alfaromeo164
« Reply #4 on: 20 Jan 2009, 04:09 pm »
Bump    Will Pay Shipping :D
alfaromeo164
« Reply #5 on: 9 Feb 2009, 10:12 pm »
Spare Tubes Included :D
alfaromeo164
« Reply #6 on: 23 Dec 2011, 09:57 pm »
Voltage Gain:  20 dB
alfaromeo164
« Reply #7 on: 23 Dec 2011, 10:01 pm »
Bump Still 4 Sale :thumb:
roscoeiii
« Reply #8 on: 23 Dec 2011, 10:32 pm »
Would you consider splitting the pre and the amps up? If so what would you like for the amps?
alfaromeo164
« Reply #9 on: 23 Dec 2011, 10:39 pm »
I Would Rather Sell Them As A Unit. Amps Only $2500
