Poll
Do you own and use after market power cords?
Yes
125 (82.2%)
No
27 (17.8%)
Total Members Voted: 152
After Market Power Cords
0 Members and 1 Guest are viewing this topic. Read 14190 times.
timind
  • permanent vacation
Re: After Market Power Cords
« Reply #80 on: 4 Jan 2009, 10:26 pm »
I voted yes but have to say I don't hear any difference. Although it's been a long time since my system has seen a stock pc.
markC
« Reply #81 on: 4 Jan 2009, 10:37 pm »
It would be interesting to hear the results if you ripped 'em all out & repled them with stock cords.
Not that I'd do that in my system-too much of a pain in the ass.
Brown
« Reply #82 on: 5 Jan 2009, 04:03 pm »
Now would be a good time to put the stock cords back in for comparison one at a time. The omission of the aftermarket cords may prove interesting. Give it a try and let us know your findings. Nothing to loose.
goldlizsts
  • Let Music Flow!
« Reply #83 on: 5 Jan 2009, 04:26 pm »
Does DIY count as "after market"?
I keep finding it interesting that so many people argue that they can or cannot hear the difference between cables and if a difference even exists.   :scratch:   Tried expensive cables and hear zero difference but it took me awhile to be honest with myself.
It's now 5 to 1 against your zero difference statement unfortunately so,,,,,, :scratch:
Actually, the poll is whether you use them, not whether you hear a difference... ;)
Let's start a thread - do you hear any difference using after-market PCs?  Then, compare results to this one may be.
BobM
« Reply #84 on: 5 Jan 2009, 05:23 pm »
Only one problem with that. You would get people answering that they don't hear a difference without actually sitting down and giving it a shot. A precondition for responding to the poll would be that you actually did a comparison and not basing a response on a preconceived notion without experimentation.
Bob
dyohn
    • the12volt.com
« Reply #85 on: 5 Jan 2009, 05:59 pm »
I've neither heard nor measured any meaningful difference.
mtodde
« Reply #86 on: 5 Jan 2009, 07:18 pm »
Aftermarket power cords seem to make more of a difference with some components than others.  I have noticed a positive difference in most cases but in one case the sound of the power amp got worse.  In fairness that power cord was not intended for a power amp and the same power cord made a positive difference in quieting my turntable motor.
I have found the JPS power cables to be a good value for the money.
planaria
« Reply #87 on: 5 Jan 2009, 10:49 pm »
I tried an exotic power cord and a power conditioner in two experimental conditions: clean-ish utility power, and power filtered through an isolation transformer.
Both products made a slight difference with utility power, but no difference whatsoever with the isolation transformer. Standard cords and the isolation transformer were the best, and cheapest, solution.
Plitron makes a very good one for a few hundred dollars - but it does growl, so you want to site it outside the listening room.
