ASKA 100 for my Kef 104.2 and the like.
0 Members and 1 Guest are viewing this topic. Read 2401 times.
srm
« on: 28 Nov 2003, 06:01 am »
Hi All,
how would this AMP go driving my Kef 104.2 Speakers.
they are currently being driven by a NAD 2600 Power AMP.
I'm looking at making a few power amps to drive my new Home Theatre System.
or will these AMPs drive Kef Q-9 DS & a Kef 202C to the same levels as
the NAD 2600 ?
regards,
Stephen.
andyr
« Reply #1 on: 28 Nov 2003, 07:07 am »
Hi, Stephen,
I believe you'll have to provide some specs to get a definitive answer - even from Hugh ("Mr. AKSA") Dean.  Like:
*  what power is the NAD2600 - ie. X into 8ohms, Y into 4ohms?
*  what is the instantaneous output current capability of the NAD2600?
*  what efficiency is the KEF 104.2 speaker?
*  what efficiency is the KEF Q-9 DS speaker?
*  what efficiency is the KEF 202C speaker?
I believe you'll find that the AKSA 100 Nirvana will:
a)  drive your speakers better, and
b)  make them sound much better
than the NAD2600.
Andy
Rocket
nad amps
« Reply #2 on: 28 Nov 2003, 11:19 am »
hi stephen,
i had a nad 2200 power amp for many years and to be honest although it had reasonable amounts of power it didn't cut it sonically.
i have a pair of custom made speakers made by war audio here in perth which use the raven 1 ribbon tweeters.  it is very revealing and did not sound very good using the nad amp.
anyway to cut a long story short i now have an aksa 100 nirvana and it easily drives my speakers which are 90db and 4ohm load efficiency.  a little difficult to drive.  the aksa has plenty of reserves for my purposes.
the amp sonically is in the top echelon of ss amps available.
regards
rocket
Rocket
nad amps
« Reply #3 on: 28 Nov 2003, 11:20 am »
hi stephen,
anyway to cut a long story short i now have an aksa 100 nirvana and it easily drives my speakers which are 90db and under 3.5 ohm load efficiency.  a little difficult to drive.  the aksa has plenty of reserves for my purposes.
regards
rocket
AKSA
« Reply #4 on: 28 Nov 2003, 11:53 am »
Stephen,
I've not tried the AKSA 100 on the Kef 104.2s, but I know the design and the drivers and I'm quite confident it would have no problem.
If you contact me privately, I might be able to arrange an audition...
Hugh
