0 Members and 1 Guest are viewing this topic. Read 1942 times.
I have had excellent results with the Soundsmith. If you get their contact line diamond, it matches the cutting tool and goes deeper into the groove. It often makes noisy records sound better.I recently had my ZYX retipped by The Soundsmith, and the results are amazing.
Cartridges can only be "noisy" if they are influenced by outside sources. They are just a bunch of coils. Too much surface noise can be caused by several things. First I would check VTA. If the tail is too high, the cartridge rake angle will be wrong and sound trebley, picking up more surface noise. I'd also be suspicious that the stylus had more hours than the ebay seller stated and perhaps the stylus is worn out..or damaged. A real good magnifier or scope should prove that right or wrong. Third, what VTF are you running? Too light of a VTF can tend to reveal a bit more surface noise.Wayner
Are you curious to see what the stylus looks like (worn, not worn)?Wayner
