The best tube amplifier made is available here.
0 Members and 1 Guest are viewing this topic. Read 1581 times.
Niteshade
    • Niteshade Audio
« on: 28 Dec 2008, 11:22 pm »
An amplifier that is the following: Riveting, engaging, true to the source, embodies non-fatiguing power reserves, has a fast response time, an elegant circuit, is easy to use, efficient and made entirely with high grade components will not disappoint. Think of an amplifier that you've dreamed of. It can become a reality. We create amplifiers that can easily drive Maggies or the most sensitive of horns and do it with authority. We know vertical and horizontal sound-staging is extremely important and completely understand how to make an amp provide tactile sensations through genuine accuracy. We build to your needs. That includes room size, speaker type and the way you like to listen plus any other information you can provide.
There are all kinds of mods available for amplifiers because the original design didn't fit the owner's idea of what the amplifier should do. Why not get it all done right the first time around? Brilliant!
We do not believe in gimmick parts and only utilize components with proven track records that justifiably improve your circuit. If it can't be explained as a good investment, we don't use it. There are hundreds of high quality components out there capable of enhancing a circuit beyond your expectations. The knowledge to pick and choose the right ones for you is here. Already know what you want in your amplifier? That's fine too. We're happy to work with you.
Our message to potential customers: Think about this seriously!  Take your time. Have questions? Please ask. Your dream amplifier is waiting.
« Last Edit: 29 Dec 2008, 11:14 am by Niteshade »
