Output Of BP-6
0 Members and 1 Guest are viewing this topic. Read 1375 times.
XKevinX
Output Of BP-6
« on: 28 Dec 2008, 02:57 pm »
I have had my BP-6 installed for a couple of days now and have noticed that I have to turn the volume control quite a bit higher to obtain the same volume levels as my previous pre-amp.  Does this have something to do with the output curve???  More after 12 O'clock and less before that???  Thanks.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Output Of BP-6
« Reply #1 on: 28 Dec 2008, 06:29 pm »
Hi Kevin,
The BP6 volume control is linear so it will operate differently than some as some preamps have more gain at the lower settings. The BP6 runs Class A so the volume control is an attenuator -- it turns the gain down not up. Normal listening should be about 10 oclock to 1 oclock.
james
vegasdave
Re: Output Of BP-6
« Reply #2 on: 30 Dec 2008, 11:31 am »
I've wondered about this too...and when you say normal listening James, are you talking about when playing cd or lp?
Re: Output Of BP-6
« Reply #3 on: 30 Dec 2008, 12:52 pm »
Hi Dave,
LP's usually have less gain so the volume control would be higher than with CD Players where the typical output is 2 volts or more.
james
