OneAC tweaks/mods?
0 Members and 1 Guest are viewing this topic. Read 1532 times.
bubba966
OneAC tweaks/mods?
« on: 27 Nov 2003, 08:01 pm »
Ok, I've been erading about these thigns for too long and decided to pick one up when I found a decent deal on one that'd fit my needs.
Was planning on a CP1103 or CP1105.
But I came across a CM1102 & 2 CL1102's for $19 + shipping. :mrgreen:
Yeah, they're a little smaller than what I was looking for. But the price was more than right. :D
So what have you all done to improve the performance of your OneAC?
I've got a few 20A hospital grade outlets sitting around as well as plenty of 10ga solid copper wiring. So I'm planning on swapping out the outlets and any possible internal wiring I can change for the better as well.
But I've got no clue what's inside these things.
So what else is possible?
Psychicanimal
OneAC tweaks/mods?
« Reply #1 on: 29 Nov 2003, 08:42 pm »
Blow the unit w/ canned air or air compressor, clean ALL contacts w/ DeOxy, rinse w/ alcohol & preserve w/ contact preservative of your choice.  Dampen insides w/ tar sheerts (Dynamat Extreme), mount the unit on cones and use cryo'ed outlets.  That should take you quite a long way...
bubba966
OneAC tweaks/mods?
« Reply #2 on: 29 Nov 2003, 08:50 pm »
Ahh, forgot about using Dynamat Xtreme. I've got a good sized sheet laying around doing nothing, guess it'll be doing something now.
Cones huh? Any particular type that doesn't cost a fortune?
Tonto Yoder
OneAC tweaks/mods?
« Reply #3 on: 29 Nov 2003, 09:00 pm »
