Need help with a Radio Craftsman C500
0 Members and 1 Guest are viewing this topic. Read 3067 times.
daves
« on: 23 Dec 2008, 01:48 am »
I am interested in learning how to troubleshoot and fix some of the simpler tube gear I have, and the RC is one I would dearly love to get running. Would one of the tube savvy solder slingers be willing to help and not laugh tooo much when I burn myself? I'll travel and be glad to loan it out as well as paying for all expenses, etc.
KenSeger
  • Heavy and noisy, but beautiful
    • Ken's Plain Jane Website
Re: Need help with a Radio Craftsman C500
« Reply #1 on: 23 Dec 2008, 10:10 am »
Just a note here.  Having no clue what a Radio Craftsman C500 was, I googled it.  Okay, 1950's, obscure brand, built like a battleship, with transformers that look serious vis a vi power output, and factoring in inflation, darned expensive.  Apparently these go for around $2,000 now in the far east?  The high end collectors in the Hong Kong, Korea, Japan, et cetra region have a 'thing' for really BIG British and American gear from the 50s.  Western Electric amplifiers, Tannoy Folded horns that are good foot taller and wider than the K-Horn, McIntosh and Marantz by the ton, Big JBL, Big Altec, Big ElectroVoice, et cetra.
So do consider that the units greatest value might lie in a listing on E-Bay.hk or E-bay.jp before you put a soldering pencil to it.
As for soldering, you'll need a kit of - a good solder sucker (pneumatic spring operated, and one that is easy to disassemble to clean), plenty of spring loaded heat sink/clamps, a serious temperature controled solding pencil/station (Bryan has the name of a good one at a good price), correct electrical flux, and plenty of practice.
Now granted that the Radio Craftsman C500, I assume, doesn't have any printed circuit boards to accidentally fry since it is all point to point soldering.  Nevertheless, if Radio Shack still sells little solder it yourself kits (if they don't Gateway Electronics, 2220 Welsch Industrial Court, St. Louis, 63146, 314-427- 6116 surely does and probably has a vastly better collection of solder, flux, flux cleaners, heat sinks, et cetra) get one, solder it together, get it working, unsolder it, solder it together again, get it working again.  By that time you'll get a good idea how much heat and time it takes to 1. make solder flow properly 2. how to avoid brittle 'cold' solder joints that are both mechanically and electrically weak.  Please note that all solders do have slightly different melting points so if you practice with cheap solder (you should start with this) and then switch to some exotic audiophile solder you might have to re-learn your timing a bit.
There a fellow over on AudioCircle Circles > Special Interest > The Vintage Circle by the name of Bill Thomas who is THE Dynaco rebuilder par excellance.  I would read his message strings and ask for his advice concerning rebuilding your C500 before you do anything.
Best of luck,
Ken
drummerwill
« Reply #2 on: 27 Dec 2008, 02:05 am »
Hi Dave
  Tha Radio Craftsman is a real nice piece of vintage HiFi audio. That amp used one of the most popular best sounding Push-Pull tube amp design of its time.
  The Williamson curcuit, and the iron on that amp is top quality. With a little work you could have a nice tube amp.
  To do stereo you would have to find an identical. But some say mono can be very nice too.
   Or there's always the ebay way!
    If you weant to try to get it running give me a PM.
  Have fun!
  Willie
