budget lomc's
0 Members and 1 Guest are viewing this topic. Read 1753 times.
slovell1
budget lomc's
« on: 22 Dec 2008, 06:05 pm »
anyone got any opions or recommendations for lomc's in the 300 dollar and below price range?
thanks,  sam :scratch:
hifitommy
here ya go
« Reply #1 on: 3 Jan 2009, 08:22 pm »
even though its late for xmas:
http://www.needledoctor.com/Benz-Micro-MC20E2_2?sc=2&category=364
click on the stereophile review.  if i didnt have plenty of carts, i might jump on this one.
Rocket
Re: budget lomc's
« Reply #2 on: 3 Jan 2009, 11:55 pm »
Hi,
I have tried both the denon dl103 lomc and benz micro mc20e2 homc.  The benz is easier to use because it doesn't need a step up transformer and can be used with a regular phonostage.
It sounds just as good.
Regards
Rod
chosenhandle
Re: budget lomc's
« Reply #3 on: 5 Jan 2009, 07:07 pm »
I have a Denon 103r. It is a great cartridge that also can be improved through tweaking. As stated earlier, it is a fairly low output cartridge (~.236mv) so you have to make sure you have the gain necessary in your phonostage.
