0 Members and 1 Guest are viewing this topic. Read 33004 times.
Crossover is at 1600 Hz, handled by a DEQX HDP3. This is the lowest freq the horn can maintain constant directivity, which has been chosen with the 8" driver, because this is where it starts to beam. The DEQX time aligns, maintains linear phase, produces a flat on-axis freq response (the off-axis is determined by the physics of the speaker), and the crossover, and other things as well.
The tweeter is a B&C DE 250 compression driver, as favoured by Earl Geddes. It certainly has excellent dynamics, but is not as detailed in the mid to upper treble as my Dynaudio Esotar, even though the freq response is ruler flat. I'm thinking of trying the 18sound NSD1095N. Anyone with any experience?The constant directivity waveguide is an 18sound XT1086, with a foam plug, as innovated by the same Earl Geddes (AES papers, patents, but OK for DIY use. It is 35 ppi (pores per inch) open cell foam, glued in place. No attenuation, but reduces HOMs apparently (higher order modes in horns).
