0 Members and 1 Guest are viewing this topic. Read 2447 times.
There are commercial products that do this. I have made one as well from rare earth magnets. You must have some sort of guide or rail system to keep the two halves in line with each other; otherwise, the platforms will twist relative to each other and quickly stop levitating. I used two small posts on the bottom platform that went into two bearings on the top. Magnets around the perimeters. Works well....
Magnets are also not a good thing to have around interconnects and powercords, so placement and spacing is important.Enjoy,Bob
P.S. you shouldn't be intimidated to post in the lab. I don't intend for the lab to be exclusive to those who already know a great deal of technical stuff. They probably don't need the lab to answer questions. The point is to learn and to share ideas. I feel like I should break out into koombyya.
The interesting thing about the magnetic isolation is that it is not a linear damping system, like springs or other "normal" damping systems. The compliance increases with the square of the distance, unlike a regular spring, which increases at a constant rate...
