What is the best way to make wood figure gain depth?
0 Members and 1 Guest are viewing this topic. Read 18784 times.
ecramer
Re: What is the best way to make wood figure gain depth?
« Reply #40 on: 29 Dec 2008, 12:58 pm »
Ordered some waterlox for my next little project, gathering stuff up to build a couple of more TT sandboxes  what kinda brushes do you guys like I have been using disposable foam as even the navy would not let me paint :lol:  Should just spring for a HVLP gun, would make my life a lot easier on these projects.
ed
BradJudy
« Reply #41 on: 29 Dec 2008, 09:45 pm »
FWIW, I use Waterlox on almost all of the wood bowls I turn.  It's a popular finish for wood turners.
I apply it with a cloth, so typically a fairly thin coat each time.
WGH
« Reply #42 on: 30 Dec 2008, 12:32 am »
ed
I prefer brushes by Purdy.
The Syntox brush worked beautifully with Waterlox.
http://www.purdycorp.com/catalog/series/detail/10
Hank
« Reply #43 on: 31 Dec 2008, 05:31 pm »
Seems like there are very few oil finish fans around.  Probably because of the no protection from water spots.   Too bad. :(
sts9fan
« Reply #44 on: 31 Dec 2008, 06:10 pm »
Maybe someone in this tread can help me.  I have made a cocobolo faceplate for a amp I made.  I am using a carnuba wax as I read online is appropriate for this wood.  I seem to be getting some cloudy spots on the wood.  I am only hand buffing.  Will power buffing help this?  It is only minor clouding that is only visible under direct light.
Kris
EARGASM
  • No thanks.
« Reply #45 on: 31 Dec 2008, 09:37 pm »
Removed by member.
« Last Edit: 25 Sep 2009, 04:12 pm by EARGASM »
EARGASM
  • No thanks.
« Reply #46 on: 31 Dec 2008, 09:40 pm »
Removed by member.
