0 Members and 1 Guest are viewing this topic. Read 5747 times.
Unless you already have a box made, you are throwing away a slew of advantages by not going bipole. One of the biggest bang-for-buck speakers of all time in the consumer world was made by EPI around 1974. It was a bipole with 4 1/2s in a small column about 7" x 7" x 36". It had openings around the base and sounded pretty good for less than $100 a pair, if I remember.
Thanks for the info. I'm a little familiar with the benefits of a bipole(of course there are downsides as well), and will probably get into it later. Since I'm fairly new to speaker building concepts in general, I'm mainly interested in gaining a basic foundation on the vented and sealed boxes first. Once I feel comfortable will the those I'll try other designs.I have several books mainly talking about sealed and ventedI'm using arta, basbox pro,xover, an m-audio sound card, and ecm 8000 to make my measurements and do tests.It has been really fun!
Maybe Dave D (planet 10) would have an opinion.
Doubling up on the 4.5" drivers isn't quite the same as listening to a floor-to-ceiling line array. In a line array, comb-filtering exists throughout the range of possible vertical listening heights, because you hear driver groups that are appreciably further from you than the driver that you are coplanar with. That added distance from your ear to each of the non-coplanar drivers creates the combing effect in the frequency response. With only a pair of drivers, however, you can achieve relatively comb-free frequency response if your head is in a horizontal plane that is equidistant from the acoustic centers of the two drivers. The further apart you space the drivers in your enclosure, the more difference you will notice at different listening heights. If you're fine with the fact that you'll narrow the vertical 'sweet spot' considerably at high frequencies by using two drivers instead of one, then go right ahead. In fact, this can be an important means of reducing room interaction.Use three or more drivers, though, and all bets are off.
Quote from: Taterworks on 22 Dec 2008, 04:21 amDoubling up on the 4.5" drivers isn't quite the same as listening to a floor-to-ceiling line array. In a line array, comb-filtering exists throughout the range of possible vertical listening heights, because you hear driver groups that are appreciably further from you than the driver that you are coplanar with. That added distance from your ear to each of the non-coplanar drivers creates the combing effect in the frequency response. With only a pair of drivers, however, you can achieve relatively comb-free frequency response if your head is in a horizontal plane that is equidistant from the acoustic centers of the two drivers. The further apart you space the drivers in your enclosure, the more difference you will notice at different listening heights. If you're fine with the fact that you'll narrow the vertical 'sweet spot' considerably at high frequencies by using two drivers instead of one, then go right ahead. In fact, this can be an important means of reducing room interaction.Use three or more drivers, though, and all bets are off.You can certainly hear a two driver comb filter. The fact that you intend to sit exactly in one spot without moving doesn't mean that it doesn't exist. If fact a three driver array would probably be better as the center driver could be at ear level and the other two would have one above and the other below ear level, giving you additional SPLs. BTW: With you ear equidistant between the two drivers means that above about 4kHz or so, you are in the null of the comb filter and you "may," or "probably will" notice a rolled-off treble. I've constructed a line array that has...are you ready for this...12 drivers and zero (0) comb filtering at the listening position! Best Regards,TerryO
