3b st and 3b sst differences
0 Members and 1 Guest are viewing this topic. Read 1512 times.
Al DAddario
« on: 16 Dec 2008, 09:36 pm »
Is there a big difference between the st and sst series? Also, will
my vintage Nakamichi 410 preamp work with the 3b?
I see some pre-owned 3b st's at very attractive prices.
The sst series is a bit expensive for me.
I have a very modest 2 channel system using Maggie MMG's.
Al D'Addario
Boston
  • The Demo is Everything!
    • http://www.bryston.com
Re: 3b st and 3b sst differences
« Reply #1 on: 16 Dec 2008, 09:39 pm »
Al D'Addario
Boston
Hi Al,
Yes there was a major change with the SST Series so definitely try to get an SST over an ST.
james
joey116
« Reply #2 on: 16 Dec 2008, 09:42 pm »
Not to start an argument with James : ) but the ST is still a mighty fine sounding amp. if that is all the budget allows I don't think you can do better.
Al DAddario
« Reply #3 on: 16 Dec 2008, 09:44 pm »
Thanks very much!
Is my Nakamichi 410 OK to use as a preamp?
I appreciate the advice!
Al D'Addario
Boston
« Reply #4 on: 16 Dec 2008, 11:06 pm »
Thanks very much!
Al D'Addario
Boston
Hi Al,
Absolutely the Nak is just fine.
james
