0 Members and 1 Guest are viewing this topic. Read 3240 times.
I learned that the Denons have discrete codes for power and input selection, so I think I'll head in that direction. I may have to get creative to record them, but at least they are there and Denon is a brand with a fairly good reputation and a product that will work in this application. (All of the Denon 09 models also have the Audyssey Dynamic Volume automatic volume-leveling system, which my parents will probably appreciate more than all of the other features!) I think I'll try to find a good deal on a refurb unit...I did look at the Onkyos, especially the 606, but ruled it out I have a fairly confined cabinet I'll have to deal with and the 606 seems to have a higher than normal heat output. The HKs looked interesting, but the more affordable units didn't have as much power as I'd hoped. Marantz has a good reputation in this market as well, but they didn't seem as competitively priced. I was least familiar with the Yamahas, but several models seemed well thought of and I found specific comments on sound quality. In the end, however, the Denon feature set won out.Thanks to both of you for the suggestions!
One thing I have heard about HK is that they are more conservative in their power ratings then others, so I would take a lower HK power number with a grain of salt.
But, I don't think you can go wrong with Denon. There are lots of happy Denon receiver owners out there, so they must be doing something right.
This place http://www.dakmart.com/advanced_search_result.php?keywords=denon&osCsid=sunmt9iivtne4uid74hb3skiq7is a b stock, authorized denon dealer.
