0 Members and 1 Guest are viewing this topic. Read 13288 times.
Well heck, it sounds like you're done and have your bases covered........Whatcha waitin' for? Bob
Most of the dedicated HT projectors I've seen around around 30-35 dB.Some of the presentation projectors are a little louder.You can always prop up a "backstop" behind the unit to block the fan noise. Picture one of those things they raise up behind passenger aircraft when they spool the engines up for take off. Just don't block the air flow. Bob
I can't say enough good things about my screen. I went with a 106" DaLite Fixed Frame High Power screen and it really helps the image pop off the screen.-Nick
