**SOLD***Parasound HCA1206 - 6 channel HT amp
0 Members and 1 Guest are viewing this topic. Read 931 times.
Big Red Machine
« on: 10 Dec 2008, 01:59 am »
Here are some photos I stole as my camera is charging right now.
I am using this for the back 4 channels and have bridged 2 pair to have 4 channels of output.
Lists at $2kish, $625 takes it + shipping.  No original box but I'm box heavy anyway.
SPECIFICATIONS
Continuous Power Output
> 135 watts RMS x 6, 20 Hz - 20 kHz, 8 Ω, all channels driven
> 200 watts RMS x 6, 20 Hz - 20 kHz, 4 Ω, all channels driven
Continuous Power Output - Bridged
> 350 watts RMS, 20 Hz - 20 kHz, 8 Ω, each bridged channel, 3+4, 5+6
Current Capacity:
30 amperes peak, per channel
Slew Rate:
> 130 V/µsecond
Frequency Response:
12 Hz - 120 kHz, +0/-3 dB
Total Harmonic Distortion
2 dB
Interchannel Crosstalk:
> 75 dB at I kHz > 56 dB at 20 kHz
Input Impedances
50k Ω per channel, without looping inputs 1/2 to Ch. 3/4 or Ch. 5/6
25k Ω per channel, if looping inputs 1/2 to either Ch. 3/4 or Ch. 5/6
17k Ω per channel, if looping inputs 1/2 to both Ch. 3/4 and Ch. 5/6
Input Sensitivity:
1.0V THX Reference Level
S/N Ratio:
> 118 dB, input shorted, IHF A-weighted
Damping Factor:
> 800 at 20 Hz
Dimensions:
19" wide x 7" high x 18.5" deep (7-5/8" high with feet)
Weight:
71 lbs. net
« Last Edit: 15 Dec 2008, 06:29 pm by Big Red Machine »
Big Red Machine
Re: Parasound HCA1206 - 6 channel HT amp
« Reply #1 on: 10 Dec 2008, 02:01 am »
