0 Members and 1 Guest are viewing this topic. Read 9892 times.
I really have just one question, which is a front-horn question, but I can't find a thread closer than this, so please forgive me if this is slightly off-topic....(the question comes at the bottom of all this crap you gotta know first!!!! )although when I explain, maybe not so off-topic after all....Having Audio Nirvana's and not being able to afford better....I have decided to try the following design:Match up an 8" AN to a front-horn, made of wood, just the way Vincent Brient did it at:http://vincent.brient.free.fr/round_horns.htm(very cool DIY project!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!) for the following REASON (explained to me by M. Brient when I mentioned matching it to a FR speaker): the AN's, being low Qts and low Xmax, but monster magnet, and central whizzer, have a rising frequency response.....the horn will mellow them out, giving more body to the low-midrange and de-emphasizing the high-frequency rise....and match to air impedance better, giving a better efficiency, and better off-axis directivity as well.So, "shoutiness" of AN's should be tamed, mid-range, especially low-mid-range, smoothed and given more body, the stereo sweet-spot widened a bit....but the design can still be open-backed, so it has mid-range reflections for ambience (right word?)....BECAUSE I'll crossover in the amp at either 250 Hz or 100 Hz and send the low-bass to a sub, so the AN doesn't have to deal with the low-bass at all, doesn't even SEE the low-bass...NOW FINALLY (SHEEZ, I KNOW!) THE QUESTION :when making the blinking horn using the tractrix computations, how do I set the diameter of the opening that mates to the FR speaker? If the cone is 8" diameter (where the edge meets the surround), then should the opening be precisely 8"? Or is there an advantage, especially since I'm not trying for low bass - that all goes to the sub - would I get better mid-range tonality from the horn by making the opening a bit smaller...say 7 1/2" or 7" or even 6.5"....even though the cone is 8"??Front horn experts, waddya think?? Best, Charlie
The AN driver will have mass roll off in a proper horn, no highs. Do you realize this?
QuoteThe AN driver will have mass roll off in a proper horn, no highs. Do you realize this?No, but thank you for telling me. I thought the horn would just tame it, I didn't know it would kill the highs completely.So, I guess I'll just ebay the AN's and take my loss, because I do want to make these horns, they look like too much fun to pass up. It's really about making the horns, if the AN's won't work, then I'll get new drivers.A passing thought, though, just for the "intellectual excercise"....couldn't I make a double horn design, a horn for the tweeter part of the FR inside the much larger horn for the main cone? There would be a few struts in the way, but oval struts at 120 degrees apart, bottom and diagonal top left and diagonal top right would probably not interfere with the mid and bass too much. The small openings of both horns can be placed fairly close to the tweeter center and outer cone, since the Imax is only about 1 mm, I think......although the inner horn will have to pretty small or there will certainly be a shadow cast on the upper midrange. There were (and still are) coax's that had an inner horn....Best, Charlie
but segment it so you can have different sized throats for different sized drivers.
The AN driver's amp can be high passed so you won't have a big cap in series with the driver. All you'll need there is a cap and resitor on the amp inputs.
A tweeter that covers 1200 Hz to 20 KHz. Now, that's a paradigm-shift!!!!!
.. then one that covers 590Hz - 22kHz would really be a paradigm shift!
