Tympani LAT in OB
0 Members and 1 Guest are viewing this topic. Read 3081 times.
Caucasian Blackplate
Tympani LAT in OB
« on: 8 Dec 2008, 06:19 am »
Any thoughts?  It doesn't look that different than the idea behind some other OB subs I have seen.  EQ'ing would be an obvious necessity I'm sure!
Polarbear
Re: Tympani LAT in OB
« Reply #1 on: 8 Dec 2008, 03:18 pm »
« Reply #2 on: 8 Dec 2008, 06:18 pm »
Interesting, although there is nothing about how the finished product sounds...
Magnetar
« Reply #3 on: 9 Dec 2008, 12:34 am »
It doesn't appear to be an open baffle
el`Ol
« Reply #4 on: 11 Dec 2008, 02:06 pm »
I just modeled the LAT as a compression driver in Hornresp and found both flat baffle (too soon rolloff) and Ripole-like pipe (flat rolloff and monstrous peak) are not ideal. I didn´t spend enough time to find the optimum angle, but a 90° V-frame opening to the rear seems to be a good compromise.
