avp 16 won't reset
0 Members and 1 Guest are viewing this topic. Read 1495 times.
winerworks
avp 16 won't reset
« on: 5 Dec 2008, 04:51 am »
My AVP 16 interface is stuck and I can't access the speaker menus. All I get is N/A. My subwoofer is now set to none and I can't change it back. I 've tried setting it to factory default but I still get the message N/A. How do I reset the AVP 16. Any help would be appreciated. Thanks
nuforce-casey
Re: avp 16 won't reset
« Reply #1 on: 5 Dec 2008, 08:49 am »
What if try hooking up the composite video to a TV monitor and use the on-screen menu?  Would it help?  Also make sure that the AVP is not in the 2-channel bypassed mode.
winerworks
« Reply #2 on: 6 Dec 2008, 12:17 am »
Thanks for the help. I was working in bypass mode. All is well now.
