0 Members and 2 Guests are viewing this topic. Read 381846 times.
Here it is:# An example configuration file for MPD# See the mpd.conf man page for a more detailed description of each parameter.# Files and directories ######################################################### This setting controls the top directory which MPD will search to discover the# available audio files and add them to the daemon's online database. This # setting defaults to the XDG directory, otherwise the music directory will be# be disabled and audio files will only be accepted over ipc socket (using# file:// protocol) or streaming files over an accepted protocol.#music_directory "/mnt/tunes"## This setting sets the MPD internal playlist directory. The purpose of this# directory is storage for playlists created by MPD. The server will use # playlist files not created by the server but only if they are in the MPD# format. This setting defaults to playlist saving being disabled.#playlist_directory "/mnt/tunes/mpd/playlists"## This setting sets the location of the MPD database. This file is used to# load the database at server start up and store the database while the # server is not up. This setting defaults to disabled which will allow# MPD to accept files over ipc socket (using file:// protocol) or streaming# files over an accepted protocol.#db_file "/mnt/tunes/mpd/tag_cache"# # These settings are the locations for the daemon log files for the daemon.# These logs are great for troubleshooting, depending on your log_level# settings.## The special value "syslog" makes MPD use the local syslog daemon. This# setting defaults to logging to syslog, otherwise logging is disabled.#log_file "/mnt/tunes/mpd/mpd.log"## This setting sets the location of the file which stores the process ID# for use of mpd --kill and some init scripts. This setting is disabled by# default and the pid file will not be stored.#pid_file "/mnt/tunes/mpd/pid"## This setting sets the location of the file which contains information about# most variables to get MPD back into the same general shape it was in before# it was brought down. This setting is disabled by default and the server # state will be reset on server start up.#state_file "/mnt/tunes/mpd/state"################################################################################# General music daemon options ################################################## This setting specifies the user that MPD will run as. MPD should never run as# root and you may use this setting to make MPD change its user ID after# initialization. This setting is disabled by default and MPD is run as the# current user.#user "root"## This setting sets the address for the daemon to listen on. Careful attention# should be paid if this is assigned to anything other then the default, any.# This setting can deny access to control of the daemon.## For networkbind_to_address "any"## And for Unix Socket#bind_to_address "/var/run/mpd/socket"## This setting is the TCP port that is desired for the daemon to get assigned# to.#port "6600"## This setting controls the type of information which is logged. Available # setting arguments are "default", "secure" or "verbose". The "verbose" setting# argument is recommended for troubleshooting, though can quickly stretch# available resources on limited hardware storage.##log_level "default"## If you have a problem with your MP3s ending abruptly it is recommended that # you set this argument to "no" to attempt to fix the problem. If this solves# the problem, it is highly recommended to fix the MP3 files with vbrfix# (available from <http://www.willwap.co.uk/Programs/vbrfix.php>), at which# point gapless MP3 playback can be enabled.##gapless_mp3_playback "yes"## This setting enables MPD to create playlists in a format usable by other# music players.##save_absolute_paths_in_playlists "no"## This setting defines a list of tag types that will be extracted during the # audio file discovery process. Optionally, 'comment' can be added to this# list.##metadata_to_use "artist,album,title,track,name,genre,date,composer,performer,disc"################################################################################# Symbolic link behavior ######################################################## If this setting is set to "yes", MPD will discover audio files by following # symbolic links outside of the configured music_directory.##follow_outside_symlinks "yes"## If this setting is set to "yes", MPD will discover audio files by following# symbolic links inside of the configured music_directory.##follow_inside_symlinks "yes"################################################################################# Zeroconf / Avahi Service Discovery ############################################ If this setting is set to "yes", service information will be published with# Zeroconf / Avahi.##zeroconf_enabled "yes"## The argument to this setting will be the Zeroconf / Avahi unique name for# this MPD server on the network.##zeroconf_name "Music Player"################################################################################# Permissions ################################################################### If this setting is set, MPD will require password authorization. The password# can setting can be specified multiple times for different password profiles.##password "password@read,add,control,admin"## This setting specifies the permissions a user has who has not yet logged in. ##default_permissions "read,add,control,admin"################################################################################# Input ########################################################################input { plugin "curl"# proxy "proxy.isp.com:8080"# proxy_user "user"# proxy_password "password"}################################################################################# Audio Output ################################################################## MPD supports various audio output types, as well as playing through multiple # audio outputs at the same time, through multiple audio_output settings # blocks. Setting this block is optional, though the server will only attempt# autodetection for one sound card.## See <http://mpd.wikia.com/wiki/Configuration#Audio_Outputs> for examples of # other audio outputs.## An example of an ALSA output:#audio_output { type "alsa" name "My ALSA Device" device "hw:0,0" # optional format "44100:16:2" # optional mixer_device "default" # optional mixer_control "PCM" # optional mixer_index "0" # optional}## An example of an OSS output:##audio_output {# type "oss"# name "My OSS Device"# device "/dev/dsp" # optional# format "44100:16:2" # optional# mixer_device "/dev/mixer" # optional# mixer_control "PCM" # optional#}## An example of a shout output (for streaming to Icecast):##audio_output {# type "shout"# encoding "ogg" # optional# name "My Shout Stream"# host "localhost"# port "8000"# mount "/mpd.ogg"# password "hackme"# quality "5.0"# bitrate "128"# format "44100:16:1"# protocol "icecast2" # optional# user "source" # optional# description "My Stream Description" # optional# genre "jazz" # optional# public "no" # optional# timeout "2" # optional#}## An example of a httpd output (built-in HTTP streaming server):##audio_output {# type "httpd"# name "My HTTP Stream"# encoder "vorbis" # optional, vorbis or lame# port "8000"# quality "5.0" # do not define if bitrate is defined# bitrate "128" # do not define if quality is defined# format "44100:16:1"#}## An example of a pulseaudio output (streaming to a remote pulseaudio server)##audio_output {# type "pulse"# name "My Pulse Output"# server "remote_server" # optional# sink "remote_server_sink" # optional#}### Example "pipe" output:##audio_output {# type "pipe"# name "my pipe"# command "aplay -f cd 2>/dev/null"## Or if you're want to use AudioCompress# command "AudioCompress -m | aplay -f cd 2>/dev/null"## Or to send raw PCM stream through PCM:# command "nc example.org 8765"# format "44100:16:2"#}### An example of a null output (for no audio output):##audio_output {# type "null"# name "My Null Output"#}## This setting will change all decoded audio to be converted to the specified# format before being passed to the audio outputs. By default, this setting is# disabled.##audio_output_format "44100:16:2"## If MPD has been compiled with libsamplerate support, this setting specifies # the sample rate converter to use. Possible values can be found in the # mpd.conf man page or the libsamplerate documentation. By default, this is# setting is disabled.##samplerate_converter "Fastest Sinc Interpolator"################################################################################# Volume control mixer ########################################################## These are the global volume control settings. By default, this setting will# be detected to the available audio output device, with preference going to # hardware mixing. Hardware and software mixers for individual audio_output# sections cannot yet be mixed.## An example for controlling an ALSA, OSS or Pulseaudio mixer; If this# setting is used other sound applications will be affected by the volume# being controlled by MPD.##mixer_type "hardware"## An example for controlling all mixers through software. This will control# all controls, even if the mixer is not supported by the device and will not# affect any other sound producing applications.##mixer_type "software"## This example will not allow MPD to touch the mixer at all and will disable# all volume controls.##mixer_type "disabled"################################################################################# Normalization automatic volume adjustments #################################### This setting specifies the type of ReplayGain to use. This setting can have# the argument "album" or "track". See <http://www.replaygain.org> for more# details. This setting is disabled by default.##replaygain "album"## This setting sets the pre-amp used for files that have ReplayGain tags. By# default this setting is disabled.##replaygain_preamp "0"## This setting enables on-the-fly normalization volume adjustment. This will# result in the volume of all playing audio to be adjusted so the output has # equal "loudness". This setting is disabled by default.##volume_normalization "no"################################################################################# MPD Internal Buffering ######################################################## This setting adjusts the size of internal decoded audio buffering. Changing# this may have undesired effects. Don't change this if you don't know what you# are doing.##audio_buffer_size "2048"## This setting controls the percentage of the buffer which is filled before # beginning to play. Increasing this reduces the chance of audio file skipping, # at the cost of increased time prior to audio playback.##buffer_before_play "10%"################################################################################# Resource Limitations ########################################################## These settings are various limitations to prevent MPD from using too many# resources. Generally, these settings should be minimized to prevent security# risks, depending on the operating resources.##connection_timeout "60"#max_connections "10"#max_playlist_length "16384"#max_command_list_size "2048"#max_output_buffer_size "8192"################################################################################# Character Encoding ############################################################ If file or directory names do not display correctly for your locale then you # may need to modify this setting. After modification of this setting mpd # --create-db must be run to change the database.#filesystem_charset "UTF-8"## This setting controls the encoding that ID3v1 tags should be converted from.#id3v1_encoding "UTF-8"################################################################################follow_outside_symlinks "yes"follow_inside_symlinks "yes"zeroconf_enabled "yes"zeroconf_name "Voyage Music Player"mixer_type "software"
Here it is:..
Change this section:audio_output { type "alsa" name "My ALSA Device" device "hw:0,0" # optional format "44100:16:2" # optional mixer_device "default" # optional mixer_control "PCM" # optional mixer_index "0" # optional}To this, please:audio_output { type "alsa" name "My ALSA Device" device "hw:0,0" # optional}And please add a # in front of this line near the end of your mpd.conf, that is, this: mixer_type "software"should be this:#mixer_type "software"or just delete line.Then issue the command, as root: /etc/init.d/mpd restartTwo problems with your mpd.conf:1. You had everything resmapled to 16/44.12. You had the software volume control enabled.Both degrade sound quality, especially if the volume in your mpd client was less than %100.Try my changes and then take a listen for a couple of days.
Terry, so glad you are back from the camping trip (hot enough?) and that these changes (especially my Hynes package ) have made things much more musical for the Alix. Look forward to you extended impressions. Question: why did you go to the trouble of adjusting the Hynes down to 12V from the 18V I had it set at? Does it matter? Wasted heat maybe?
Yes, it's exactly what I heard with the Hynes/Alix. I seem to remember, too, that the weight/heft tended to settle in after the Hynes was in place for, say, 48 hours. The USB cable will settle in a bit, too (even though it is used).
The Paul Hynes has transformed the Alix into something interesting. I hope it only gets better for me as I listen. The ONLY complaint I can muster is I'd like the sound to have a bit more weight to it. It's not necessarily thin sounding, but I think the Duet had me used to heavier tone. What's "correct"?
I don't know if what I am about to say is an apples to apples comparison, but when I inserted my Placette RVC (passive via the use of Vishay S-102 hand trimmed resistors) into my system I noticed something along the same lines as what you're describing. I thought the system sounded "thin", but after prolonged listening and contemplation I realized that my system became more transparent. Some would suggest that the "warmth" people think they're enjoying in any given hi-fi system is most likely a layer of distortion introduced by some component. The more I listened to my system without an active preamp the more I realized that things sounded a bit more like they sound in real life: a violin at Carnegie; a bouzouki played at a Greek wedding (or by Stephin Merritt -- http://en.wikipedia.org/wiki/Stephin_Merritt); youths on an NYC subway platform banging drum sticks on 5 gallon buckets, etc. They all sound, crisp, clean and pierce the air with authority. They never sound "warm" but do sound beautiful nonetheless.
Terry,Actually, the theory on the silver usb cable makes sense to me as I typically hear the same things (with a couple of noteworthy and expensive exceptions). The standard starlight usb cable, if anything, is a tad heavy on the bass in my system, though not overdone. If you can pick up a new or used db audo labs Essential usbcable, those too are quite nice, especially if cryoed.Also, fwiw, just about every piece of digital gear I've ever had pretty much sounds it's best after 36-72 hours of being powreded on and are the only components in my system that I just leave powered on. It often takes that long for everything to reach thermal equibrilium, and that seems most important to digital components. Like I said, fwiw, but to my ears it definitely makes a difference.-- Jim
Terry,Just curious, have you tried any footers and/or damping/weight on the box? One of my alix bxes has some herbies baby booties on it and for the time I was using it, that did make a nice, audible difference, and as with the mac mini, the whole presentation can be tuned with different footers, mass loading, etc. It is easyto try and can be dirt cheap, ultra expensive, or anywhere in between. Just something you may want to try if you haven't already.-- Jim
I do also have a question regarding hi-rez playback. If I shut off all down sampling and any mixer stuff, how is it my non-hi-rez DAC can still play 24/96 files? And I tried a 24/192 file, and the DAC played it but it would play for 1 second, drop out for one second, play for 1 second, etc. I didn't think it would play at all. Strange.
The way we have mpd.conf setup is to pass along bit-perfect audio to your DAC without any molestation, i.e., don't convert streams to 48Khz, etc. But ALSA will try to it's best to play a file for you under certain circumstances...My Ayre QB-9 will handle sample rates of 32Khz, 44.1, 48, 88.2, 176.4, and 192 at 16 bits and 24 bit word lengths. If I feed it any combination of these it will pass them to the DAC as is. But, if I send a 24/96 file (i.e., with this specific mpd.conf and ALSA setup) to a 16/44.1 DAC, it will do its best to down-sample the file and send it to the DAC.I think there is a way to prevent this, but the end result is no audio and a vague error message. The reason you get pauses with 24/192 material is that the 500Mhz geode CPU isn't fast enough down-sample 24/192 to 16/44.1 in real time.The alternative is to find a software sample rate converter you like and convert some of your hi-res material so that the Alix doesn't have to do it in real time.I hope this simplified explanation clarifies what's going on.P.S when all I had at one time was a 16/44.1 Wavelength Brick USB DAC, I did like the fact that the Alix could down-sample some of the 24/96 material I had. It also sounded quite good!
I really like the tone of my Alix/Tranquility/Keces combo.I would like to have more bass.Jeff
