Amplifier for Kismet Speaker
0 Members and 1 Guest are viewing this topic. Read 1841 times.
Rapt
« on: 5 Dec 2008, 12:40 am »
 Hi all,
       I hope to order a pair of kismet speakers after I get some of my finances straightened out (later down the road would like to add the candela and kismet amps). I have one of the older (smallest)  sim audio (celeste) pre and power amp. Would these be a good match as far as power output etc.. Here are some specs.
      http://www.simaudio.com/celep5003.htm
      http://www.simaudio.com/celew4070.htm
satfrat
Re: Amplifier for Kismet Speaker
« Reply #1 on: 5 Dec 2008, 12:52 am »
The Lorelei's are rated for 150watts so 85 watts shouldn't be an issue. But as Klaus preaches, system synergy might be. You won't know til you listen. I can say that my Butler amps work darn good with my Lorelei's and being rated at 150wpc, I haven't had any clipping problems with them. I have had them connected to a 250wpc Butler amp that did infact overpower the drivers so I would imagine you're better with a little less than a little more than the rated 150 watts. :D
Robin
