Rev4 TVC outputs
0 Members and 1 Guest are viewing this topic. Read 2241 times.
jmck407
Rev4 TVC outputs
« on: 4 Dec 2008, 07:57 am »
Quick question. Have a rev4 tvc  using the XLR outputs connected to a pr of Odyssey Mono Extreme SE's.  The amps are connected to av123 mini stratas:  http://av123.com/manuals/stratamini_manual_v1pt6_web.pdf (pgs 9-10), that use a powered woofer, and have line level inputs that accept preamp line outs.   Does the rev4 send simultaneous outputs on the XLR and both rca outputs...if so thinking I could  use one of the rca outputs to feed the line level inputs on the mini stratas.
John
PromitheusAudio
    • Promitheusaudio
Re: Rev4 TVC outputs
« Reply #1 on: 4 Dec 2008, 08:37 am »
YEs both XLR and RCA is connected so you can use both at the same time
jmck407
« Reply #2 on: 4 Dec 2008, 08:47 am »
Thanks for the quick reply.  Will be trying this out to see if there is any SQ improvement.   :thumb:
BTW the TVC is great.  Have one of your older DACs also.  I like to use it with my integrated tube amp, and a tube dac with the odysseys.
