blackgate caps in a piccolo
0 Members and 1 Guest are viewing this topic. Read 2061 times.
jameshuls
« on: 4 Dec 2008, 05:46 am »
Has anyone replaced the stock electrolytics in the piccolo with blackgates? I am curious whether this would be a rewarding upgrade given the $11 a cap (for NX), meaning ~ $150 for the upgrade, not to mention trying to fit the larger caps on the board. Seems like the only way to do it would be to mount them on some other board... or something. I am envisioning an Uber-piccolo with all Blackgate non-polar electrolytics, 0.1 uF FT-3s, Texas components 2375 nude resistors in the chosen signal path (just in the loading and gain values which are ideal for your cartridge), Elma or seiden audio grade switches, some Furutech female RCAs all of which would be run off the Bugle power supply, housed in a nice custom chassis of some kind... aa
Knowing that the closer you get to the source in an analogue system, ususally, the more beneficial the mod or tweak, I can't help but think such a project would be worth the price - maybe $4-500 I would think... Compared to the price of a good cartridge? Peanuts!
I have been running my piccolo into a parasound phono pre while I get my cornet running, so such a project would not make sense until I hear it through the cornet. I am sure that compared to the relatively lifeless and flat presentation of the parasound the cornet will be revelatory! However, i will start taking donations now for the piccolo project, so the funding is in place when the time comes :wink:
alpa6
Re: blackgate caps in a piccolo
« Reply #1 on: 7 Dec 2008, 05:55 am »
Everywhere i have read blackegates do sound better than regular electrolitics.
bluesky
« Reply #2 on: 7 Dec 2008, 10:20 am »
I suggest that if you are going this route then the Super E is worth it, I put some into a tube amp and found the noise floor to drop markedly which provided better detail and a bigger soundstage. BUT, that was only a pair and doing all the Piccolo's electros would be very expensive!
Perhaps you could use some Wimas or silver micas as small bypass caps to get a good improvement without a lot of expense.
Cheers
Bluesky
jameshuls
« Reply #3 on: 8 Dec 2008, 04:06 am »
I do have a mess of 0.01 Russian Teflons I could try out for bypass caps... Hmmm now you've got me thinking...
