0 Members and 1 Guest are viewing this topic. Read 6845 times.
Nichicon (not Muse) capacitor that where switched to Os-cons of some sort?Just thinking
FYI--The Oscon (solid aluminum with organic semiconductor electrolyte) caps that they put in there are great caps, IMO. Very low ESR, and they are quite compact as well. They are not cheap, either...In any event, I don't want to start a war about "which cap is best", but the Oscon's are fine caps.Peace, LeeQuote from: Destroyer of Smiles. on 7 Dec 2008, 12:43 am Nichicon (not Muse) capacitor that where switched to Os-cons of some sort?Just thinking
Quote from: cryoparts on 7 Dec 2008, 01:25 amFYI--The Oscon (solid aluminum with organic semiconductor electrolyte) caps that they put in there are great caps, IMO. Very low ESR, and they are quite compact as well. They are not cheap, either...In any event, I don't want to start a war about "which cap is best", but the Oscon's are fine caps.Peace, LeeQuote from: Destroyer of Smiles. on 7 Dec 2008, 12:43 am Nichicon (not Muse) capacitor that where switched to Os-cons of some sort?Just thinking Lee, Am I correct that the resistors are an add-on output attenuator to bring the PA-output levels down to home hifi?Jan Diddenwww.linearaudio.nl
Quote from: janneman on 16 Dec 2008, 06:47 pmQuote from: cryoparts on 7 Dec 2008, 01:25 amFYI--The Oscon (solid aluminum with organic semiconductor electrolyte) caps that they put in there are great caps, IMO. Very low ESR, and they are quite compact as well. They are not cheap, either...In any event, I don't want to start a war about "which cap is best", but the Oscon's are fine caps.Peace, LeeQuote from: Destroyer of Smiles. on 7 Dec 2008, 12:43 am Nichicon (not Muse) capacitor that where switched to Os-cons of some sort?Just thinking Lee, Am I correct that the resistors are an add-on output attenuator to bring the PA-output levels down to home hifi?Jan Diddenwww.linearaudio.nlJan, Yes, Clayton adds those in to the stock DCX for that purpose.Tom
What type of Os-cons are those? They must not be Sanyo at that size.
