What to clean equipment with?
0 Members and 1 Guest are viewing this topic. Read 1396 times.
diofan56
« on: 4 Dec 2008, 03:25 am »
Hi all!
What does one use to clean fingerprints, etc. from audio equipment such as amps, preamps, cd players, etc.?  I was thinking a product such as Windex.  Does it make a difference what is used if the equipment is anodized or painted?  I don't want to wipe off any lettering.
Dave
JimJ
  • Ut Prosim
Re: What to clean equipment with?
« Reply #1 on: 4 Dec 2008, 06:55 pm »
I've been wondering something similar...I've got one piece of gear with a brushed aluminum faceplate & two amps that are in Hammond cases with a black painted finish, I try not to touch stuff but I'd like to know if there's any recommended way to dust so I don't scratch the paint, in particular...any dusters to try that don't have any chemicals, or maybe a soft microfiber cloth?
Crimson
« Reply #2 on: 4 Dec 2008, 07:04 pm »
This is what I use. Works like a charm. Do NOT use any liquids or solvents.
nathanm
« Reply #3 on: 4 Dec 2008, 07:13 pm »
The best and most versatile cleaning product is a fine 100% cotton AudioCircle t-shirt available from this fine web emporium:
http://www.printfection.com/audiocircleshirt
In addition to looking dead sexy and demonstrating your exquisite taste if Hi-Fi web forums, the edge of these shirts make great portable polishers for numerous items.  They remove all of the audiophile's worst enemies: dust, fingerprints, children, pets and smoke residue.
Steidl Guitars
« Reply #4 on: 4 Dec 2008, 07:45 pm »
I'm with Crimson.  A soft flannel dampened with warm water and, if necessary, a bit of mild soap.  It's what I use on lacquer finishes.
Haoleb
« Reply #5 on: 4 Dec 2008, 08:19 pm »
costco has a 36 pack of yellow microfiber towels for like 15 bucks in the automotive area, I have used them for a few years with great results, If something is really dirty, Just get it a little damp with water first. Ive also used windex from time to time but have stopped since i started using the microfibers.
diofan56
« Reply #6 on: 6 Dec 2008, 01:51 am »
Hi all!
Thanks for the replies!  They are greatly appreciated.
Dave
