0 Members and 1 Guest are viewing this topic. Read 5554 times.
Is the woofer connected to the dual mid/treble section?Yes, It's all one piece.
What are their dimensions?14.5" W X 26.5" H X 6" DNow I have to decide on building a shelf or get stands.ClydeSorry I don't know how to use the quote feature.
You just 1) click on the "quote"button, then the word "quote" in brackets will appear in the reply, then 2) copy and past the text you wish to quote, behind the bracket and then 3) click on the "quote" button again and it will place another bracketed quote after the text. It will then appear when posted as the above I just quoted from you.
