0 Members and 1 Guest are viewing this topic. Read 5918 times.
check out the AVA site here:Audio by Van Alstine.
Also, I've noticed they are both rated for 300 Watts @ 4 ohms, whereas the Songtowers are rated for 250 max. Could this be a problem?
Jim also says the ATI amps are decent as well.
And 7 channels of Audio Research gear for someone shopping for a $2K amp? Lets add Krell and Lamm to the list too
Quote from: Qwertyzor on 30 Nov 2008, 12:30 amAlso, I've noticed they are both rated for 300 Watts @ 4 ohms, whereas the Songtowers are rated for 250 max. Could this be a problem?Most of these ratings are useless. For instance, if you look at the ratings for the Outlaw, if you're running 4 ohm speakers, it lists an output of 300 watts x 7 = 2100 watts, but then lists a "maximum power consumption" of 1800 watts. How can it produce 2100 watts if the maximum consumption is 1800 watts? Plus, 2100 watts is over 15amps, and although the specs don't list this, I'm sure the maximum amperage is only 15 amps. Finally, you'll never listen at anywhere near these levels. I used to run five channels of amplification through a device that told me the amperage, and I never got much more than around 5amps, and that includes running a TV, preamp, DVD player, etc, and blasting at unbelievably loud volumes.
