SqueezeCenter Starting but not Running
0 Members and 1 Guest are viewing this topic. Read 2665 times.
rklein
  • My finest audio piece ever!!
« on: 28 Nov 2008, 03:48 pm »
Howdy:
I am having a problem when I start up the computer that my SqeezeCenter Software is on.  The SB3 icon comes up in the lower right of my screen.  However, all it does is say "Starting" and it stays this way unless I exit out of SqueezeCenter and then get back in to it.  Sometimes I have to do this several times before the software will say "Running".  Anyone else experience this??  Any suggestions would be mucho appreciado! :D  BTW, I did not have this problem until I went to the 7.2.1 version.
rklein
kgturner
Re: SqueezeCenter Starting but not Running
« Reply #1 on: 28 Nov 2008, 04:48 pm »
i have the same problems too sometimes. the icon will display in the task bar and it will continually blink, but squeezecenter won't start. i have to close it and then reopen it before it will work. it's only happened a couple of times, but it always works on the second start. i'm using squeezecenter 7.0. unfortunately, i have no suggestions as to how to get it start right the first time every time.
kevin t
