CD duplicators
0 Members and 1 Guest are viewing this topic. Read 5389 times.
jtwrace
    • TIPP YouTube Channel
Re: CD duplicators
« Reply #20 on: 13 Dec 2008, 12:25 am »
Very interesting.  What model do you use?
Russell Dawkins
Re: CD duplicators
« Reply #21 on: 13 Dec 2008, 01:58 am »
Telex, with 7 Lite On burners and a 40 GB hard drive for 36 playlists. Telex is no longer in this business, but these things are a dime a dozen now.
chosenhandle
Re: CD duplicators
« Reply #22 on: 31 Dec 2008, 05:46 pm »
Update:
I ended up buying the Tascam duplicator: http://www.tascam.com/products/cd-d11u.html
I have copied about 10 CD's so far at various burn speeds (4x, 8x, 16x). I used EAC to compare checksums and wavs against the originals and so far so good.
Thanks to all for your input. If anything out of the ordinary happens, I will post it, otherwise, I am a happy camper!
TONEPUB
Re: CD duplicators
« Reply #23 on: 31 Dec 2008, 06:29 pm »
Thanks for the info, good to know...
I just bought it because it was convenient!
