Record Cleaning Putty
0 Members and 1 Guest are viewing this topic. Read 3169 times.
RJ
« on: 28 Nov 2008, 03:41 am »
Anyone tried using "Silly Putty" to clean a record?
I just ordered a pound of it in bulk. When I try it out I'll post my results.
Ron
« Last Edit: 28 Nov 2008, 02:38 pm by RJ »
SET Man
Re: Record Cleaner Putty
« Reply #1 on: 28 Nov 2008, 03:49 am »
Hey!
   Seriously?
   I'm afraid that it will leave some residue on the LPs   :scratch:
   Anyway, let me know how it turn out for you. :D
Take care,
Buddy :thumb:
Wayner
« Reply #2 on: 28 Nov 2008, 12:56 pm »
After you use the silly putty to clean off stubborn "cling-ons", use some diluted isopropyl alcohol and wipe down the grooves with a very nice soft cotton towel. this should remove any residue left by the putty.
Wayner
drphoto
Re: Record Cleaning Putty
« Reply #3 on: 28 Nov 2008, 03:21 pm »
Does a microfiber cloth work well?
Wayner
« Reply #4 on: 28 Nov 2008, 04:37 pm »
Gosh, I would sure think so.
W
orthobiz
« Reply #5 on: 28 Nov 2008, 06:01 pm »
I have a couple of records that have single skips. I was pretty good with record care throughout my life but maybe something got on 'em along the way. Nothing visible...
I used Vinylzime (I had a bottle hidden away after all) and the skip is still there.
I have some alcohol based cleaners, also.
Wondering if silly putty would work.
I heard regular silly putty is about as good as the 70 dollar clear bubble (Onzow?) for cleaning the stylus, too.
Paul
Wayner
« Reply #6 on: 28 Nov 2008, 07:09 pm »
I have a favorite album with a skip in one spot. I don't have anything to see small enough to have a look-see, just as you orthobiz. Is it a piece of shiet in the groove, is it damage to the wall, I just don't know. There is no scratch there either. The stylus hits it and then.......skip. Maybe I'll try some silly putty.
Wayner  :lol:
Listens2tubes
« Reply #7 on: 6 Dec 2008, 03:48 am »
Once dirty do you just rinse the Silly Putty off and stow till your next cleaning session?
