Music Server HDD Specials
0 Members and 1 Guest are viewing this topic. Read 3747 times.
audio_builder
« on: 26 Nov 2008, 03:06 pm »
I just got the Fry’s flyer and a 1TD hard drive is $109!!!!!! and a 1TB HDD in a case with USB, eSATA, and Firewire is only $145!!!
Makes me wish I had not bought my 500GB $200 HDD.
http://shop4.frys.com/template/onad/product_navigation/spot2
zybar
Re: Music Server HDD Specials
« Reply #1 on: 26 Nov 2008, 04:03 pm »
Here is another great deal from a better HD vendor:
Seagate Barracuda 7200.11 ST31500341AS 1.5TB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive (bare drive) - OEM  for $139
While you are getting 500GB for only an extra $30, it is an OEM  drive (which means no cables, screws, software, etc...)
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148337
I will be buying a couple to put into my new tower pc.
George
Se7en
« Reply #2 on: 26 Nov 2008, 07:27 pm »
George
As an FYI, Ive had some major issues with the Seagate drives (more than 5 failures over the last 3 years) and am now only using Western Digital. In my case these were all external drives so YMMV. Regardless of which drive you go with, a backup is always a good idea.
Hoots
« Reply #3 on: 9 Jan 2009, 08:54 pm »
I bought one of the 1.5TB external Seagate drives that was on sale 9 ($139 on-line from Frys, $149 from best buy).
I have 300 gb at the moment of FLAC on a htpc w/m-Audio REVO card in the closet behind my setup where I have a cable throught wall for connection. this provide silent operation in the listening room.
i can display my library on the HT screen using Meedio or I use remote desktop and often FooBar to run the jukebox from my laptop.
