Cary Audio SLI-80 F-1 integrated amplifier - Tube amp with headphone jack!
0 Members and 1 Guest are viewing this topic. Read 2851 times.
Todd R
Beautiful Cary SLI-80 F1 model, 9 months old.
Original box, manual, bias probe, and remote. New Svetlana 6550 tubes this July (I have the receipt). 2nd owner.
Big full powerful sound, can be changed from 80 wpc in Ultralinear, or 40 wpc in pure Triode with a simple flip of the switch! Also has one of the best headphone outputs I have ever heard
This special F-1 upgraded version of the SLI-80 made for and sold ONLY by Upscale Audio, see complete details here: Upscale Audio F-1 The F-1 adds the following features over the stock model:
Jensen oil and copper capacitors
Hexfreds in the power supply
CD input wired with Kimber Kable
WBT Speaker terminals
Grayhill Selector switch
Special finish
Perfect condition apart from a tiny chip on the center transformer beside the screw, touched up & virtually unnoticeable.
Prefer a money order but can accept PayPal or Credit cards if necessary.
Asking $2495 + 50 Lbs shipping from 49112
Circuit Type Push-Pull Ultra-Linear Pure Class AB-1
Power Output 40 Watts - Triode
80 Watts - Ultra-Linear
Input Sensitivity .45 Volt for full output
Noise and Hum -82 dB below full output
Frequency Response 19 Hz to 23 KHz +/- .5 dB
Inputs CD, AUX 1, AUX 2
Tubes 2 ea - 6922 Input Buffer Preamp
2 ea - 6SN7 Pre Driver/Phase Inverter
4 ea - 6550 Output Tubes
2 ea - 5U4 Rectifiers
Speaker Posts 5 way, gold-plated
Tube Sockets Ceramic w/ silver pins
Power Transformer 1 ea. - EI Laminate, Silicon Impregnated
Output Transformer(s) 2 ea. - EI Laminate, Silicon Impregnated
Resistors 1% Metal Film
Capacitors Oil filled coupling, (copper optional)
Power Supply Capacitors 2 ea - 1200µF @ 450 VDC
6 ea - 10µF @ 400 VDC Film & Foil
AC Cord 3 Conductor Shielded, Detachable
AC Power Requirements 117/234 VAC @ 50/60 Hz
Consumption 166 watts - Operation
Warm-Up Time 3 Minutes
Break-In Time 100 hours of playing time
Finish Textured black steel chassis with machined, black anodized aluminum front panel
Weight 42 lbs
Dimensions 7" H x 17" W x 16" D
Carl V
Did I miss the $-price being asked??
Todd R
Whoops!
Thanks for catching that.
The ad is fixed now.
