24/192 from Mac Pro
0 Members and 1 Guest are viewing this topic. Read 3168 times.
wappinghigh
24/192 from Mac Pro
« on: 24 Nov 2008, 10:09 am »
Over on another forum, a poster has confirmed that if running VISTA 64Bit on his mac pro, he can get 24/192 out of the optical out. But when he switches back to OSX, he has to go back to 24/96.
Could anyone confirm this. If so, what is the hold up on OSX's midi playing up to 24/192????? as it is clearly a software not hardware issue.....
AB
Crimson
Re: 24/192 from Mac Pro
« Reply #1 on: 24 Nov 2008, 11:46 am »
I've run 24/192 to a borrowed Fireface 400, so I know for a fact that it works. I do know, however, that without the device connected and/or appropriate drivers loaded AudioMidi will max out at 24/96.
Panelman
« Reply #2 on: 19 Dec 2008, 04:05 am »
Crimson,
do you know if the optical output of the MacBook Pro will output 192?
Sean
Crimson
« Reply #3 on: 19 Dec 2008, 12:45 pm »
Crimson,
Sean
I'm pretty sure both the USB and optical ports are limited to 24/96 (although Apple claims the optical port can do 24/192 but I haven't heard of anyone doing it). The only way to get 24/192 is via firewire. Also, as an aside, the optical ports on the Airport Express and Apple TV are limited to 16/44.1.
Panelman
« Reply #4 on: 19 Dec 2008, 07:18 pm »
Thank you, that is what I am finding with the optical so at least I know it's not an issue on my part. I've been using the USB mainly but know that more discs are coming out at a higher rez I was revisiting the optical output.
Sean
Panelman
« Reply #5 on: 22 Dec 2008, 03:54 am »
Crimson when you used the Fireface 400 were you passing the digital to an external dac, and if so do you know if the Fireface output 24/192? According to their webpage it does but interested in your thoughts.
Thank you
Sean
Crimson
« Reply #6 on: 22 Dec 2008, 03:50 pm »
Thank you
Sean
No, I was feeding it 24/192 data and using its analog outs.
