Upgrade question from 9.02
0 Members and 1 Guest are viewing this topic. Read 1381 times.
SkyBlue
« on: 21 Nov 2008, 03:24 am »
Hi,
What is the upgrade path from the 9.02 version?
Does one receive a completely new unit/new case or is the board replaced in the same case that you send in?
Just curious for now...thanks for the information...
rustydoglim
    • www.nuprimeaudio.com
Re: Upgrade question from 9.02
« Reply #1 on: 21 Nov 2008, 01:15 pm »
Ref 9 -> Ref 9V2 -> Ref 9V2SE (you can go direct to Ref 9V2SE off course)
We replace the face plate, entire amp board, adjust the power supply, serial number, restart the warranty (for the amp board, so keep your sales receipt).
We don't replace the cover. But if your cover is all scratched up, you can order new cover for $45.
If your amp packaging box is in very bad shape, we replace it.
