Ampzilla/SST Ambrosia preamp by James Bongiorno, $3290 (new $7500)
0 Members and 1 Guest are viewing this topic. Read 3439 times.
James Romeyn
Ampzilla/Spread Spectrum Technologies Ambrosia preamp by James Bongiorno
Seller is original owner, serial number 1035 shown in picture, purchased new 7 April 2007 shown in receipt picture; five year OEM warranty expires 7 April 2012.
Includes:
Owner manual
Warranty card
Milled solid aluminum remote
RCA shorting plugs for open SE inputs
Inner & outer cartons; all packing foam
XLR shorting plugs for open balanced inputs
Gold plated SE adapter for balanced XLR “combo jack”
Excellent condition, no abuse, no visible wear of gold plating on jacks;  sum total one visible scratch located on top cover under penny in large view; close up w/ penny for scale.
Fully balanced circuit; designer is inventor of the full dual-differential full-complementary amplifier topology.  Enjoy the Music Best of 2008 Award by senior professional reviewer Dick Olsher: http://www.enjoythemusic.com/superioraudio/equipment/0308/ampzilla_ambrosia.htm
Ambrosia is all solid-state; Olsher is a long time lover of the best tube preamps & amps.
OEM website: http://ampzilla2000.com/index.html#Ambrosia
Eleven pictures: http://s246.photobucket.com/albums/gg105/ro7939/Ambrosia%20preamp/
Seller prefers the Ambrosia over Dan Wright’s $4500 balanced tube preamp heard at T.H.E. Show January 2007; seller carefully auditioned the $17k VTL 7.5 & $15k Krell EVO & places the Ambrosia in similar territory to both (preferred over the VTL).  After twenty months of regular use seller can still identify no audio thumbprint or signature.
All front panel controls repeated on remote milled from solid aluminum: ½ dB volume steps, balance, transparent-in-use bass/treble (four poles each, ganged & separate L/R), 20 dB cut for high-sensitivity systems, channel reverse, mono, two tape monitor/record/copy circuits, etc., etc.
10V RMS maximum output, dual headphone jacks 4.5W (“full output into 30 Ohms”), separate high-quality MM & MC phono inputs w/ dedicated tape outputs separate from line stage, 50 lbs, 14 gauge steel construction except for front panel, “all metal surfaces including front panel are powder coated”, custom proprietary ultra-low emission power transformer in its own can, drive any conceivable load for bi-tri-quad-amping, pre-out: two pairs SE, two pairs XLR.  More features & control functions than any other known audiophile preamp.
Sell locally or purchase w/ confidence from Fire Department Captain of major CA city (verifiable).  Pay by Pay Pal, direct bank account deposit or certified bank check.  Will ship within one business day after receipt of payment.
Partial trade credit only for Mitsubishi HC6500 or Panasonic PT-AE3000 (no other trades considered).
