0 Members and 1 Guest are viewing this topic. Read 3486 times.
Just purchased a Larger "Tallboy" off of Craigslist and I'm wondering if I can turn it on it's side as the newer versions are. Possibly a little more WAF that way.Anything I should look at when hooking it up?
I did a quick check of the surrounds on the front and they seemed OK. Couldn't see much of the passive radiator though. I'm very comfortable putting some oak on the case to have it look finished. Once I confirm that all is OK I may try that. I've got several amps to drive this beast. What's the best way to connect to the drivers: mono to each or run a jumper between them and drive the amp bridged?
Going to try upright for the time being. I've just moved and had to track down my patch cords for my amps - just about to go buy new ones and found out the wife had unpacked them and put them in the basement. Everything seems to be working but the output is less than I expected. Not sure what I should cross this over at. Options are from 80Hz to 250Hz on my Denon 3805. Definitely not boomy which is something I didn't want but when listening to LOTR I expected more punch than I'm getting.
