0 Members and 1 Guest are viewing this topic. Read 8199 times.
Nice development in this thread!I guess the reason I like tubes in my audio system is due to my father having to manage them in the military computers he cut his teeth on!We brough back the first Commodore 64 to my neighborhood from the US one summer, and were the envy of the neighborhood. I remember learning to program Basic on the PET... had to be late 70's or early 80's.
Beat this, original Apple with AMBER monitor . . . . added a 10 MEG external HD the size of a shoebox for only $900! "No way we'll ever need that much storage space"
Isn't the only drawback slowing down of the interface/processing time? I did the update and the music folder searches were frustratingly (2-3 seconds) slow so I de-volved back to v 6.5.4 and it improved considerably.My CPU has 1GB of ram and I did just order another 2GB of additional ram to see if that helps the SC processing speeds.MSRP, YMMV.Kenreau
Some of the bugs fixed in the latest version are related to the operation of the DUET controller.BUT...I do find the current official release to sound very good with modded SB3 and the DUET.Very recommended
jonwb,The phase inversion happens because the analog section op-amp has been removed as part of the mod.The VERY early firmware, 15 and older, also inverted the phase. Using firmware 15 and a modded SB2 would keep the phase "correct"Over the years, the software and firmware has improved a great deal. More features have been added and bugs fixed.A phase inversion "switch" has not been part of the improvements. If you do update the firmware, the phase of the analog signal will be inverted if you are using an analog modded SB2 or 3.I personally feel the improvements in the software and firmware are worth changing your speaker wires polarity around to correct the phase.mgalusha has written a firmware selector so you can run different versions of firmware with the software. I am not sure how well firmware 15 works with SqueezeCenter 7.0 and laterI am also working on a tube analog section for the modded SB2/3 that inverts phase to normal and increases the gain to standard CD output level.
