remote control handset
0 Members and 1 Guest are viewing this topic. Read 2960 times.
Max N
« on: 16 Nov 2008, 01:03 am »
Hi John
I have one of your stepper kits from around May 2004. Unfortunately I left the batteries in the remote handset and they leaked and so the handset doesn't work anymore.
If I buy another OneForAll remote or similar, can you tell me what codes I should use to get it working?
Many thanks
Max
John Chapman
    • http://www.bentaudio.com
Re: remote control handset
« Reply #1 on: 17 Nov 2008, 02:42 pm »
Hello!
The stepper remotes think they are Daewoo TV sets. I chose these for the robust codes and also thinking the chances of having a Daewoo TV on at the same time as the music system was pretty slim.  Most universals have codes for a Daewoo TV that will work fine. If you get stuck drop me an e-mail and I'll fire a fresh remote to you.
Thansk!
John
Max N
« Reply #2 on: 2 Dec 2008, 06:36 am »
Thanks very much John
(Sorry for the delay in replying.)
