0 Members and 1 Guest are viewing this topic. Read 3742 times.
Speaking with the manufacturer, they said that to really get the best out of these, you need to have amplification in the 150W range (for bass drive, etc.).
I really hope there's a way that Isabella with higher gain plus 70.2's would do it, as it is a different kind of amp design which might make up for the lower W rating.
Thanks Vinnie,Yes, I would love to get some higher eff. speakers, and have been interested in the Zu Def 2's. However, I can't do it all at once - economy presents a bit of uncertainty. You do have a 30 day trial period, so I want to try the 70.2's. I just have a hunch they'll work. And then of course going to higher efficiency speakers later they will be the best choice. Will call this weekend or Monday...
Even at 88 db efficiency IF your speakers can be biamped, two sets of the 70.2 monoblacks should work just fine. What do you think Vinnie? Paul
I don't play concert level.
since I have biamp posts (two sets per speaker), what if eventually there were 4 monoblocks. Would that substantially change the power equation? I know enough to not just assume that this equals 2x the power. But maybe it does
