0 Members and 1 Guest are viewing this topic. Read 3403 times.
Though I've not heard them, from what I've read OB bass systems seem like the way to go in terms of convincing sound reproduction. Plus, it seems like a cost effective solution.Why then would anyone want a conventional box sub? Is it because OB sub drivers are pretty large (15"-18") and you can get away w/ smaller, more compact size in a box?Can an OB woofer be simply mounted on a baffle, which is affixed to a base to hold it upright? (Possible w/ some sort of truss type braces for ridgity) Think 'mini magnepan' for a mental image.
If there is a thread or site that explains this, please point me there. I looked at the MJK article and it didn't really help me.
Burber[sp?]
kahunas
So a proper sentence with those words spelled correctly would be:"My Berber carpet and cojones are the same color".
I wasn't sure about the Kahunas, but the spellchecker said it was fine.
Now, are U-frame and H-frames more or less open ended boxes? What's the difference beween the two? Does the box contribute to the sound via loading, like a waveguide, or is just a way to make the baffle more ridgid?
