0 Members and 1 Guest are viewing this topic. Read 5967 times.
I preferred this (sorbothane):"Selector Pack— Includes five plain-back 1 1/2" x 3" x 5/32" thick oval pieces, one of each durometer (30 OO, 40 OO, 50 OO, 60 OO, and 70 OO). 8514K2 Per Pkg. $11.45" (from Mcmaster-Carr)to the stock cones on my 4JRs. I thought they had better integration of mids to bass, allowing the speaker to speak with one voice.Buy two packs of 5 and use 1 pack per speaker. If you don't like, you're not out too much $$ or use them under something else.-Mike
Ever read up on how Verity does theirs? Thick Aluminum plate sandwiched between Sorbothane pieces. They say the Aluminum does the trick.
Quite a ways back, I had asked Paul Garner at VSA about this and he said not to spend any big $$$ on trying to better separate the top & bottom units on the VR4's. He recommended small (I don't know how many ounces) lead fishing weights that were ever so slightly higher than the gap between the units now, just to get the top unit off of the rubber pads that are on the top of the woofer cabinet from the factory. He said that if you had to "take a hammer" to the weights to either adjust the height and/or flatten them a bit so they wouldn't roll around, they would work fine. I can't say I've tried it, but it's a cheap enough tweak to try and if it doesn't improve the sound of the system, you can still go fishin'! I'd be interested to hear whether anybody has tried this.
My VR4 SR MkIIs have conical rubber "tiptoes" on the upper mid/hi enclosure with tips pointing down. They are seated in small holes drilled in the top of the lower woofer enclosure. You apparently have a different arrangement.
