PRODUCT INFO: Super 8 Alnico Series
0 Members and 1 Guest are viewing this topic. Read 2437 times.
Louis O
« on: 14 Nov 2008, 02:16 am »
If you want the best Omega has to offer, the 8 Series is for you.
Addition of 8-inch Alnico drivers to Omega’s flagship product offering brings the 8 Series speakers to a new level of performance.
Just how much better are Alnicos compared to Omega’s current 8-inch ferrite Hemp drivers?
“…Alnico drivers leave the wonderfully rich midrange of the standard drivers (ferrite Hemp) intact, while providing for considerably improved focus and articulation in the high and low frequencies.” – AudioCircle.com Member
Super 8 Alnicos excel compared to their smaller siblings, in they do everything their siblings do, only better. Specifically, Super 8 Alnico’s deliver:
- Greater dynamics (i.e. more ‘whomp’ you can feel in your gut!)
- Better defined and more open bass response
- Improved bass texture
- Higher power handling capacity
- Greater surface area on the drivers, allowing them to reproduce more complex musical passages, while maintaining clarity and focus
Super 8 Alnico Monitor: Pure listening enjoyment!
$2,500 / pair
Some compare the sonic (and magnetic) differences between Alnico Magnets (Aluminum-Nickel-Cobalt) and Ferrite Magnets (Strontium Ferrite), akin to the sonic differences found in tube amps compared to solid state amps: “…(a) solid state amp gives it all its got then clips hard, while a tube amp compresses nice and smooth.”
No matter the physics, Alnicos are the best sounding drivers I’ve ever heard. That’s why they’re now standard equipment in all Omega upper-end speakers.
Yes, they’re more expensive to manufacture compared to ferrites, but in my opinion Alnico drivers are one of the best investments you can make to upgrade your listening experience.
Two speakers in one.
You can run Super 8 Alnico Monitors as sealed enclosures to optimize their musical purity. Or choose to go vented, maximizing their low-frequency response.
Super 8 Alnico XRS: Exceptional musicality & ‘room friendly design’
$3,500 / pair
The Super 8 Alnico XRS is a completely-new speaker for Omega.
Super 8 Alnico XRSs incorporate a new Aperiodic vent. A ‘lossy,’ down-firing vent, helping the speakers perform at a level sonically larger than their physical size.
Aperiodic vents delivers improved musical purity, because the drivers are transient perfect. Something not achieved by traditional vented enclosures.
Like all Omega XRS-style speakers, Super 8 Alnico XRSs interact with your room to extend bass output. And built-in brass cones tilt the front of the speaker slightly for optimal soundstaging. And like other XRS models, this speaker is ‘room friendly,’ working well in a variety of room placements -- even close to your corners and back walls.
This model shares design characteristics found in Omega’s smaller XRS speakers, including:
- Extended bass response
- Short cabinet heights, which virtually eliminates cabinet flex and resonance problems, translating into pure, uncluttered mids and highs
- Wide front baffles & built-in tilt, opening and broadening the soundstage
- All XRS’s are floorstanders, so you don’t need special speaker stands, making Super 8 XRSs just a wee bit more budget friendly.
A purely beautiful listening experience.
Whether you’re thing is Beethoven, Krall, Miles or Hendrix, the Super 8 Alnico XRS brings you so close to ‘lifelike,’ you will absolutely be amazed!
