0 Members and 1 Guest are viewing this topic. Read 6506 times.
I read MJK’s very helpful paper from http://www.quarter-wave.com/OBs/U_and_H_Frames.pdf This shows for a single woofer amongst those three options, the H Frame has (slightly) the lowest f3 and the most output around 250 Hz. In exchange for the lowest efficiency. With an H frame, if the 'wings' were on all four sides, rather than just two opposite sides, would it probably make only a small difference if the two woofers to be used per channel, were side by side, rather than on top of each other?
OTOH, if the ‘wings’ were to be on all four sides, in a rectangular shape eg 16” * 32” (to accommodate two woofers) there will be a second set of quarter wavelength resonances. These would be at half the wavelength (from the added sides 32” apart) of the resonances from just a pair of wings 16” apart. So in Martin’s example, all other things equal eg with a depth of 7.5”, there would be an added resonance at 131 Hz . .
In the formula on page 3, what is R_effective? And in the formula on page 10, is c the speed of sound?
Thanks Martin, you understood the scenario.In a rush . .I understand and agree with most most of your points, excepting > you should think of the floor as a mirror and visualize a second cabinet under the floor. I understand that . . > Each orientation doubles in height. . . but what do you mean by that?
More importantly > The open end also provides a fair amount of damping that removes energy from the enclosure sending it out into the roomYou don’t think that damping boosts (iirc) output below Fs, as johnk advocates?
you're a fountain of information
